Point Cloud rendering on HoloLens - Performance
CornKrue
in Discussion
Hello everyone,
Has anyone experience with rendering point clouds on the HoloLens.
I'm interested in the performance of the HoloLens when rendering models with 2 - 5 Mio RGB data points. Will the HoloLens be able to do that? What FPS can be expected´?
Thank you very much in advance for sharing your experience!
@CornKrue,
Try it out: https://github.com/MarekKowalski/LiveScan3D-Hololens
Thank you for your answer, I know the LiveScan viewer for HoloLens.
Nevertheless I'm interested in the experience of people about the amount of points, that can be rendered on HoloLens without major performance impediments.
A slightly related question. Does anyone have an app or some source code that will process a static point cloud (preferably in xyz format) in the Hololens?
Only some experience: 9 million points where to much for the HL in my test project, 330.000 was ok.
@Peter_NZ: I have slightly adapted the scripts from https://www.assetstore.unity3d.com/en/#!/content/19811 for reading a simple obj format.
