Downloaded emulator but it won't install?
when I click on the emulatorsetup.exe in my downloads folder, it says I have everything that I need, and then will let me download all over again ! ??
My windows 10 pro install is new, also Visual studio 15 and community is new, and unity install is new. Not sure why I cannot run the emulator. No error message.
If you have no error message than probably you didn't turned on Hyper-V. Go to "Turn Windows fatures on/off" and check the Hyper-V option
Ummm, turn it on where? sorry. Windows, Unity ? thanks
By default you should be able to launch the HoloLens emulator from Visual Studio 2015. Follow the tutorials it will take you step by step on how to work with the emulator.
Dwight Goins
http://dgoins.wordpress.com
As it turns out, I needed to start up a virtual machine using HyperV manager. Still working out those settings.
