Best possible way to load 3D models on the fly
prasadl
in Discussion
Hello Everyone,
I want to load 3D models (FBX) dynamically at runtime from a remote server. So the end user can load new 3D models directly from the HoloLens app. Does anybody know how to implement this kind of scenario?
The asset store has some examples though I am not sure if there are any free ones. I believe there are free OBJ importers:
https://www.assetstore.unity3d.com/en/#!/search/page=1/sortby=relevance/query=fbx&importer
@MattFedoCSG Thanks for the suggestion, I tried using assetBundles but when I load an animated model, I couldn't attach the AnimationClip dynamically without using UnityEditor scripts, If I use UnityEditor Scripts I can't build the project. Any solution for that?
@prasadl what I would do is package my character with all its animations in the asset bundle. Then when I go to unpack the asset bundle, I would pull all the animations from the bundle and use the AddClip() to the animation controller. Check out this link for some code : https://forum.unity3d.com/threads/solved-load-animations-from-asset-bundles.34827/
