LeanTween plugin with unity beta - not working!
Acylum
in Discussion
Has anybody gotten LeanTween to work with the Unity Hololens beta? I tried to import, but it doesn't recognize any LeanTween commands. I don't know if there is something else I need to do or Unity Hololens doesn't work with any other plugins
I posted on the slack but will here as well. I've never tried LeanTween but highly recommend DOTween and can confirm it works on Hololens.
Plugins will work on Hololens but you need to make sure they are compatible with UWP and Unity 5.0.
How can I use DOTween to make sure that can run on UWP and Unity 5.X
It supports UWP and Unity 5 and says so in its description: https://www.assetstore.unity3d.com/en/?gclid=CPvpive1jcQCFQEIwwodCVIAvg#!/content/27676
It lists Windows Store and Unity 3.5-Unity 5.x
I also use it and can personally confirm it works without any modifications.
