Collision between player with glasses (camera) and hologram character
Hi. I thinking about collisions between player wearing glasses and holograms. Do I need to add a collider to another game object (representing player) connected with camera? What's recommended way of doing such things in Unity? I have found interesting thread on https://forums.hololens.com/discussion/572/got-my-game-idea-stealth but with any code. Any samples or code or good resources on Internet?
OptionsJarrod1937 ✭✭✭
I achieved this by creating a box with collider that is attached to the main camera. This allows the camera to collide with holograms, however, the box as a whole allows you to also approximate collisions with your body. I do ray casting down from the camera to get the distance from the head and floor, so that I can scale the box to the users height dynamically. This allows me to keep a constant volume in relation to the change in the users height, for better approximating body position (expand more in the opposite direction of the facing direction).
A simpler method could just be a box with collision disabled for the spatial mesh but enabled for everything else. This would allow you to have the box actually go through the spatial mesh (it's not visible), but allow collisions no matter the body height. It just depends on how strict your requirements are.P.S. Look for an update on the stealth game within a month or so!
6
Holograms like player also walking on a floor.
Thnx very much for answer, I'll try your tips. You really helped me. Btw I have found a quite interesting article about similar things on https://hololens.reality.news/how-to/hololens-dev-101-create-user-location-hotspots-trigger-events-with-hololens-0176979/. It uses a sphere collider on HoloLens camera directly, but it's not advanced to scale it to the user height dynamically. Do you think it could be possible to use a collider attached directly to camera with height based on distance between camera position and raycast down point with floor or using a cube is necessary? In my case the best collider would be a capsule, but I could try another shapes like cube or even sphere.
@Jarrod1937 writing "by creating a box with collider that is attached to the main camera" you thought about box attached to camera and collider attached to box or just a box collider attached to camera. In the thread on https://forums.hololens.com/discussion/572/got-my-game-idea-stealth you mentioned about second option (collider attached to camera), I'm right?
For testing purposes I did an actual box with an attached collider. This allows some level of visualizing things. However, you can just add a collider to the camera directly or via script.
Thnx. I have started building a box with collider / a collider attached to main camera. But I have a new question. A collider attached below main camera on floor could be a problem when I raycast down from camera to floor to measure distance? How to resolve it?
Maybe, should I placed camera inside of a collider to have collision with floor?
Use layers to restrict your raycast to particular classes of objects. Right now, if you look at your camera object's inspector window, in the upper right, you'll see that the Layer is set to Default. You should either create a custom layer for all other app objects or alternatively set the camera layer to one that is not part of Physics.DefaultRaycastLayers (https://docs.unity3d.com/ScriptReference/Physics.DefaultRaycastLayers.html), such as the "Ignore Raycast" layer.
Bart
http://trzy.org
Thank you for your tip. It has helped me. I have box in IgnoreRaycast layer under camera and measuring distance with raycast works well, but I have one more problem. I'm using path finding with dynamic NavMeshAgents. Before placing box under camera on floor characters were going towards camera (me), but now they aren't moving properly. Maybe because their target point under camera is inaccessible because of box. How can I solve it?
I have managed with it using position of cube (player), not point under camera covered with it. I don't know if my solution is ideal, maybe in my case capsule collider would be better, but something started working...
