Click and Drag to draw a box
Is there a way to click and drag(airtap and hold and move and release) to draw a box(3D plane) using HoloToolKit?
@ctsholo you can use HandDraggable script from HoloToolKit on your object to click and drag, it is located in HoloToolKit > Input > Script > Interaction folder
You could use the IInputClicked interface. OnInputDown you get your first corner of the cube and with OnInputUp you get your second corner of the cube. Then you have your diagonal vector of the cube and you can calculate the center of it. Then adjust your scale depending on how long the diagonal vector is.
Make sure you also implement the OnSourceLost method of the ISourceStateHandler interface, so you know when hololens cant recognize your hand anymore.
Thank you for the response. I followed this tutorial to make this work https://billmccrary.com/holotoolkit-simple-dragresizerotate/
