Holograms 210 - Gaze, can't see full picture of Astronaut
Hi
I have tried to follow the Holograms 210 - Gaze. When I finished the part 1, I found I can't see full picture of astronaut (only 2 feet are shown). I thought it might not follow the guide correctly. However, I tried to load the complete project coming along with the zip folder. And I got exactly same thing. Could this be a device issue, or any thought?
Thanks.
Optionssazure ✭
Another thread inspired me. The reason is because I'm running as debug instead of Release. When I switched to release mode, everything looks normal.
6
You are sure that you are not to close to the hologram right?
@sazure could you please paste a screen shot or some other information about what you see? That will help us diagnose. Like @gorgepir mentioned, please ensure you are not too close to the astronaut.
Another thing you could try is, change the Z coordinate on the AstroMan and push it out further in the positive Z so you see it away from you. Or you could even consider playing with the scale of the AstroMan.
I'm very sure I'm not close to AstroMan, I have been walk around and trying to find a good angle to see the full picture, but unfortunately I'm getting middle picture as a black screen.
Do you have any quick easy way to take screen shot in hololens? Or any link has mentioned this part? If so, can you please highlight the instruction how to take screenshot in hololens in this forum so that everyone could have better way to communicate with you guys.
Sazure,
You can take a screen shot from the Windows Device Portal webpage.
See if this link helps you take a screen shot.
Thanks Patrick. I can't capture a picture during running other app. But I got a video and capture a screen as here showing how that looks like.
And I have cleared everything and reload it, it shows the same thing. Also, I noticed device turns to be quite slow.
I also tried increase z position, and it doesn't help.
