Holograms 101 - Origami running success, but when adding more ...
First, I'm not really a unity guy. I have successfully running Origami. However, next step, I want to add more contents into scene. So I started with the Flying crane coming with the demo code. I found my cursor can't hit most of the Crane. As you can see the following picture. My cursor is working with given objects in tutorial. But when I drag crane to the scene, the cursor can only hit the right wing, but not the rest part of crane. I also tried add 3rd party free prefab object, they will not get hit by cursor at all. But if I just simply add a cube into the scene, it will hit that cube. Can you please help me understand how I can get any 3rd party object get hit by the world cursor (when spatial mapping is enabled). Thanks.
101.jpg 112.1K
    Most likely you need to add a 'mesh collider' component to your game object. You can do this in the inspector in unity. In some cases (like the astronaut in the gaze course) there are multiple meshes in the object and each will need to have a mesh collider added.
    Thank you, Patrick. This is what I did in project. Can you please take a look if it is correct? With this setting, I'm still getting the exact the same result.
    I had to tinker around a bit, I'm getting closer (the animation isn't updating the mesh collider).
    Thanks, Patrick. Now cursor is hitting the most part of crane. I'm seeing it is hitting the bot of wings but not top of wings, but I guess it's ok.
    Also, I verified it while animation is playing and cursor is indeed hitting crane too. This is perfect. Thanks!
