Difference between HoloToolkit and Holo Academy scripts?
Hey,
So far I've been using the scripts from the Holo Academy tutorials to perform all the different gestures, actions and the like in Unity. However while looking through the HoloToolKit on github I found a lot of the scripts to be structured very differently, tapToPlace, HandDraggable etc. Is it recommended to use the scripts from the tutorials or use the scripts from the toolKit?
OptionsJesse_McCulloch admin
My recommendation is to use the scripts from the HoloToolkit. They are both more recent, as well as better practice than those found in the Academy courses. Those found in the academy are great for getting something done and having a quick win, but they are not always the ideal way of doing things.
6
