Render Flicker yellow red blue
Have anyone experienced weird flickering in the Hololens display when moving your head upd and down vertically it flickers and shows colors in yellow, and red and blue lines. It doesnt happen if you move your head horizontally.
Ive tried my app on other Hololenses and the same happens.
Ive stripped down the unity scene of any object but 1 cube, and still flickers. so is not shader, mesh density, texture related.
And if it s code related then why performance doesnt change if I keep the head still?
Dunno, its a weird issue we're trying to solve.
OptionsPeter_NZ ✭✭✭
You will get this if you FPS is too low. Are you running Debug or Release? Debug slows the frame rate right down so this problem may disappear when you run release mode.
Thanks for the answer, indeed I was building in Debug mode, frame rate drastically improved in release mode and the yellow flicker was way less noticeable now.
