How to save anchor for later usage?
Hello, happy to say that I am new to HoloLens development. I am very excited to explore more on this technology.
Anyone knows how to save anchor position for later usage or any sources for example/tutorial.
More details on what I want to achieve:
I want to save anchor of objects in physical spaces using my Spatial Mesh.
Then I want to use the anchor position saved in (Step 1) to initialize the position of my object in when relaunches my app or use anchor in other apps.
What I am able to do:
I tried to import my room model using Spatial Mapping component.
I also tried to add room mesh .obj file into Hierarchy of my project. The purpose of this to visualize my room model in unity editor in order for me to put my object in specific position in physical space. After that, I've attached World Anchor component to the object.
Lastly, when I launch my apps, the object will not go/stay at the physical space specified earlier. In fact, the object appears in random position in front of my camera view.
Question:
Are there any easier ways to use World Anchor Manager because this component is lack in tutorial and example on the internet.
Is anchor saved data accessible (for later use)?
Thank You.
Hi Frank,
You can do about 1.5 to 2 steps of what you propose. You can use the anchor manager to save your world anchors so when your app restarts, objects will go back to where you last left them. The HoloLens Academy tutorial even shows you how to share anchors between two devices in the same room. https://developer.microsoft.com/en-us/windows/mixed-reality/holograms_240
You can't share your anchor with someone in a different space, though. And while you can potentially use the dev portal to grab a mesh of your room, this isn't really what HoloLens is using underneath with the anchors, as I understand it.
So while you can potentially copy the mesh and copy your anchor and share them, they won't work together on someone else's device.
I don't want to be discouraging because it's a cool idea. But anchors and room meshes aren't the right way to pull this off, sadly.
Hi James, thanks for quick response.
Yeah I know that I can save my anchor using world anchor manager. But the only example that I know of is TapToPlace.cs from HoloToolkit. World Anchor in this example need to be set by the user in the apps at the first place. Instead of that method, I want to set my world anchor in development process so that when I deploy my apps I don't have to set them all.
Thanks.
