app works in unity perfectly, but not in hololens
h_x
Hi guys,
this is a issue bothers me really several days. i have created an app, everything works perfectly when i hit play button in unity, but as soon as i deploy it in hololens it doesnt work. the script doesnt work is always the ones which activate/deactivate or enable the object.
anyone has such experience too?
Not all content from the Assets folder is automatically included in the build. For example when you instantiate objects at runtime, you have to place the prefabs in a folder called 'Resources'.
Can that be the problem?
hello,
i am confused then. should i then manually put all the stuff in the right folder before i build? i have never done this before.
the problem which kind of weird is: the same script, "activate the object", it is randomly somehow doesnt work. i have the experience that it works in scene A, if i add scene B to it, then it doesnt work anymore, altough there is no connection between any of this scripts. any idea?
Is there a way that you can share your script or project?
or when i deploy the app, i always start without debugging. would it also be a reason?
Start without debugging has never caused problems for me. Indeed it is difficult to guess what could cause the problem without any project and code.
