Capture left and right images from Hololens
Hi all,
Can I use the HoloLens as a stereo camera? I want to capture left eye and right eye images from the HoloLens and render them in stereo. I am guessing if I am able to capture with the Hololens, I would be able to display them with better fidelity in the Hololens.
Hi
you can use the locatable camera to take images with the HoloLens. Check this link for implimentation guides.
The images are taken from the center of the camera. Therefore you would have to move a few steps and take a second image. Afterwards you can try to use these image to do stereo-vision.
