Spatial understanding mesh problem
in Discussion
I use this mesh for scanning rooms and I noticed that when I scan enough time the mesh goes higher and higher (every point separately).
like some kind of offset between reality and the mesh.
I'd like to know if anyone else encounter this issue and if I do something wrong that cause this, or it's a known bug.
for now I take a reference point and maintain its height.
I'm using HoloToolkit for unity.
thanks,
Mor.
OptionsCarlvH ✭
I have experienced something similar. I have not found a real solution but it helped to reset the Space inside the HoloLens Settings.
5 -
OptionsCarlvH ✭
@mor_sayag : Yes. Unfortunately this will delete all the apps your placed in your room and is not possible inside an app.
Hey
what do you mean by "gets higher and higher"? Is the y-value (Height) of each mesh-Point increased over time?
Hey, thanks for responding.
yes, that's exactly what happens.
do you know how to solve it?
Ok, thanks.
Do you mean that deleting the space helps?
