Regarding Microsoft Academy Holograms 240
Hello
1. I am following the steps given by the Microsoft team ,I am stuck at Chapter 3, Shared Coordinates.The problem is I am able to deploy as shown in the video for the first hololens .But how do i deploy the same one on the second hololens. Should I use 2 PCs and deploy into the hololens from 2 different PCs or is there any way i can deploy into hololens from a single PC.
Thank you for your response @dyama .I have done the same way how you have mentioned in the above steps for second hololens. But still if I do any tap gesture and explode the anchor on the on the first hololens ,I have to see the same thing on the second hololens. But there is no connection between these two hololens and both users wearing hololens are not having any communication with them.Please help I am stuck here since couple of days .
Chapter3 missing
KeyNote Missing is: I am not able to palce EnergyHub even after 120 seconds.
