Launching a MixedReality immersive headset app. Can Someone Help?
Can someone suggest me how to launch a Mixed Reality App for immersive devices(Acer , HP) from APPX App package which i also successfully installed but when launching just running in window mode but not in immersive mode. Please you can check the screenshot for reference.
what would be the issue , is there any guidelines?
Is this a Unity app?
In Player Settings, you need to make sure that Virtual Reality Supported is checked.
In recent Unity 2017.2.* builds, you can find this under XR Settings.
@timg Yes Virtual Reality supported is already checked.
I've found the solution BTW It seems after updating the window insider program it is working in immersive mode.
Thanks for your time.
