Which physics color is best to use, black or white? or something in the middle.
in Projects
Hey,
as the question say, we gone build a exhibition booth where visitor can try the hololens the idé is to change between different color of one of the walls. The question is now what color should we paint to get best effect?
my idé is that black is better that you get more sharper look. any one have any experience or ide of this?
Thanks.
Black is hard for the device to pick up. White (or any light color) in a lit room is much easier for the device to see.
If you have a device it would be best for you to test looking at different colors of walls and lightning combos to see what works best for your goals.
