Hi @andymoz
I have gone in Windows Feedback and selected Mixed Reality Category then put "Surface" in the Search area. Then I have somewhat cheated by upvoted all the entries whether Acer or HP headset where mentioned.
Originally in Windows Feedback we upvoted when we felt an entry important.
So its up to you whether or not you get the votes trending, Top Votes
There are a lot of Surface problems reported and wonder if these are being addressed as well.
IMHO this does NOT give me an incentive to consider the new Surface 2 as if they cannot fix the original which had a bad start and left problems, how does this inspire confidence in the newly designed device only two years old.
Should maybe the title be "Getting a USB Device not found when plugging ANY Windows Mixed Reality Headset in my Surface book"
This puts the problem squarely in Surface Book Microsoft hardware support, maybe they just don't regard us as real customers
Was hoping for a miracle yesterday as there was a new firmware bundle for all surface devices released (even surface book).... 16299_1705000 for surface book at the Microsoft site.
.... but alas. No.
Well @Jesse_McCulloch and @andymoz the real miracle would be to release the source code onto somewhere like GitHub, very unlikely .
Therefore if you load the Windows Developer kit
you get a great tool called (C:\Program Files (x86)\Windows Kits\10\Debuggers\x64\USBview.exe) USBview.exe. HowTo.
This shows the USB root layout and more important identifies the problems on the right when you have a problem with devices not identified correctly.
Then you could share a screen dump of the failing.
This is my working USB 3.0 hub with my Xbox One Kinect 2
This will NOT fix the problem but, when you delete the "FailedEnumeration" port in Device Manager you can try again and see if the error is constant.
Maybe this will provide someone with the information to fix this as they are unlikely to release the source as "not fit for public consumption" was the "old" HP phrase, and they could not get it past the lawyers!!
Would be nice if someone posted a working version of a Windows Mixed Reality Headset USB dump. When my HP Headset is arrives and working then probably will post screen dump.
There is an issue with surface book usb firmware driver that leads to the enumeration failure. The workaround in this article resolves the majority of issues.
https://support.microsoft.com/en-us/help/4032123/kinect-sensor-is-not-recognized-on-a-surface-book
I think you have cracked it.......No USB errors and a Mixed Reality Device showing UP!!!
Couldn't just delete the device and re-scan, but needed to remove and re-insert.
You are a star.
Also now running it directly from an un-docked surface book with usb and display port adapter directly into the base..... on an original surface book without the performance base. All good.
Now I can’t get my hands on it! ..... pesky kids.
It works now for me too
Well... It works... But it is not a nice experience ... I think I have to upgrade to a 1050... So when will MS starts selling Surface Book bases?
- take your base into the local Microsoft store and just ‘see if the performance base fits it’ then forget to take it off again :-)
There are no Microsoft Stores in Germany... Sadly... Would be hanging there most of the time...
I was in New York and I am not lying... I was there everyday.
@andymoz I edited my registry and my surface book recognizes the device! So...is anyone having this problem? The headset is recognized, it lets me configure my controllers, then the screen just flashes over and over like its trying to switch screens and nothing inside the headset. When I disable the Intel Video Card in the device manager it doesn't recognize it as apparently the Nvidia card doesn't allow a 2nd device to display. Everything is tied to the Intel video card?
Not all MiniDP adapters function properly. There is a list of supported adapters here:
https://developer.microsoft.com/en-us/windows/mixed-reality/recommended_adapters_for_windows_mixed_reality_capable_pcs
With the registry edit suggested before I got my Acer MR headset correctly recognized but I have the screen flashes issue. I am using a Surface Book with Windows 10 build 16299.19 and Surface Mini DisplayPort to HDMI 2.0 Adapter (which is officially supported). Any idea about how to solve this?
Giorgio
Do a windows update, the latest drivers should download and install. Also I had an HP MR, it required downloading and installing the latest firmware for the device. the firmware was updated from the MR Portal, and the driver from standard windows update.
hth
Dwight Goins
http://dgoins.wordpress.com
@Dwight_Goins_EE_MVP My Surface Book (btw, the original one with GTX940-equivalent GPU) is updated with all the latest drivers. I tried two other miniDP-to-HDMI adapters without success, display keep flashing when Acer MR is connected. I also tried to force dGPU or iGPU (avoiding "Automatic" GPU selection) but still no success. I was hoping it would work after the successful registry edit but unfortunately the Surface Book seems to be incompatible.
@gcifani my surface book (original one with GTX940) works. Initially my screen flashed, however you have to let all the updated drivers download. I also had to install a new firmware on the HP MR (done automatically through portal) and then once that was done there was one last windows update:
![](https://us.v-cdn.net/6
026774/uploads/editor/du/iq7xwwr0k3bf.png "")
Now my SB works with the HP MR device. Not the best experience in the world but enough for development, placement, initial tests etc, It's not good enough for Demos to showcase capability in my opinion.
Also I'm not on any insider on the SB, Windows 10 Pro and 16299.19 as well.
Dwight Goins
I finally got it to work on my Surface Book (Nvidia 940M) after changing the registry and getting that supported mini DisplayPort to HDMI adapter from Cable Matters. Performance is not good, but I managed to improve it a bit by choosing Low quality for MR Display in MR Portal and setting my primary display (Surface Book's screen) to lowest resolution possible (800x600) to take some heat of my poor GPU. Good enough for development.
@Dwight_Goins_EE_MVP I have the very same driver installed (Microsoft Holographic 10.0.16299.1012), no luck. @jakovd thanks, it seems is not worth any extra effort the resulting experience...
@andymoz - I have the Surface Book Performance Base and compared to my desktop which is also currently running on 60Hz the Surface Book has the following problems:
1) It lags too often - Turning my head around too fast for example may often results in the view not following my head movement
2) I can see a minor flickering
3) the graphics are not clear - more blurry if further away
4) The textures in the cliffhouse are not great... Its blurry and the details are mostly gone.
5) I cannot use the desktop without lag
6) playing a game in the VR Desktop will give you headaches
7) Simple SteamVR programs like Universe Sandbox is a lag-fest
8) WebVR works but the textures are blurry even if it is set to HD.
I tried this workaround.
...and used this miniDP-HDMI Adapter.
club-3d.com/en/detail/2366/displayportt_1.2_to_hdmit_2.0_uhd_active_adapter/
My Surface Book solved in this way.
This worked on my SurfacePro 4 i7 for my HP HMD. Performance is not great as expected, but just being able to use immersive VR on an ultrabook from 2015 is pretty freaking cool Thank you!
FYI - I am using this adapter: Cable Matters Gold Plated Active Mini DisplayPort to HDMI Male to Female Adapter Supporting Eyefinity Technology & 4K Resolution
Just to let people know - this setting gets put back if you install the surface dock 'firmware updater'. So, if you update your firmware on the dock (there was an update on the surface dock recently), then you'll have to remove the lower filter entry again.
Uh...I am currently using Samsung Odyssey HMD, changing the registry is actually not working, and the Microsoft official MR page have been update and says the SB is not able to use MR after I bought the device... They actually says SB performance is able to use MR before. I will never trust them anymore
What do you delete? I'm just a student right now so I've never dealt with this stuff before.
Could you help explain that work around?
I figured it out. you run 'regedit' and then go here
and then delete what is says inside 'lowerfilters', I think the data inside was "surfacekwupdate" or something.
Now everything works nicely.
