ADAL for Unity?
I'm wondering if there a version of ADAL that works with Unity exists? Either that or what method should be used to do Azure AD logins for hololens apps?
OptionsRob_VS mod
There are a couple of ways to make this work, depending on what all features your tenant is using. I have not been able to successfully get this to work with MFA.
You can use the ADAL libraries, but had to wrap you code in #if UNITY_UWP blocks to hide it from the Unity editor.
I actually found it a bit easier to authenticate against the OAuth endpoint directly to get my access / refresh tokens. I essentially created a FormUrlEncodedContent with all of the necessary information (grant_type, resource, client_id, username, password, etc...) and then did a post directly to the endpoint.
Once I had my token, I then used that directly against the GraphAPI endpoint to query additional information.
Let me know if you have additional questions
