Fetch real time data from PLC device - OPC in HoloLens?
Is it possible to implement OPC UA client in HoloLens so that it reads real time data from from a PLC device ? Are there any examples of the same, on how to integrate OPC client in Unity? If this is not possible then is it a good approach by setting up a OPC client on cloud and HoloLens fetches data from that through web sockets? Please guide me.
Take a look here:
http://opcfoundation.github.io/UA-.NET/
You should first try to compile and running the samples ..
btw - I'm trying also to implement a (simple) OPC-UA -client to Hololens ...
What I can say fro now: it seems possible !
@DrNeurosurg Thank you. I will try it and if you don't mind please update your progress of your implementation later.
sure ...
@DrNeurosurg Can you please share your experience with OPC client in HoloLens?
Were you able to get OPC UA data working on HoloLens?
@DrNeurosurg @ctsholo Were you able to get the OPC client operating in Hololens?
