Where could I find the Holo Toolkit for the unity3d version 2017.2.0f3?
When I tried with older version Toolkit, I am getting an error in Visual studio stating some exceptions. I think it is due to incompatibility of toolkit with the unity version. Where could i find the Toolkit for 2017.2.0f3.
Thanks in advance.
Optionsmark_grossnickle ✭✭✭
All of the Toolkit versions can be found here:
https://github.com/Microsoft/MixedRealityToolkit-UnityTaqtile
@mark. Thanks for the response. I am new to the hololens development. I have gone through that repository already. but I couldn't find anything which is compatible with my unity version 2017.2.0f3. When I tried using with other unity packages, the solution file ends up with some exceptions on run time.
The entire repository should be compatible with your unity version.
What exception are you seeing? Lets start there.
Also, make sure you have the latest UWP SDK installed.
