Creating voice command synonyms in GRXML
(I have tried asking it on StackOverflow, no answer so far, gonna try my luck here)
I've created a voice controlled Hololens application in C++/CX (hand-made, no Unity). A very simple one, mostly according to some samples, this is the speech recognition event handler:
void MyAppMain::HasSpoken(SpeechContinuousRecognitionSession ^sender, SpeechContinuousRecognitionResultGeneratedEventArgs ^args)
    if (args->Result->Confidence == SpeechRecognitionConfidence::Medium
        || args->Result->Confidence == SpeechRecognitionConfidence::High)
        process_voice_command(args->Result->Text);
Everything works so far, the recognition result is in args->Result->Text variable. Now, I only need to support a very limited set of voice commands and simply ignore everything else, but within that limited set of commands I want some variability. It seems, the last example on this page is exactly about that. So I made the following grammar file based on that:
<grammar version="1.0" xml:lang="en-US" root="nextCommands" xmlns="http://www.w3.org/2001/06/grammar" tag-format="semantics/1.0">
  <rule id="nextCommands">
    <item>
      <one-of>
        <item>next</item>
        <item>go</item>
        <item>advance</item>
      </one-of>
      <tag>out="next";</tag>
    </item>
  </rule>
</grammar>
What I want with it is that when I say either "next", "go" or "advance", the recognition engine just returns "next", so it is in the args->Result->Text above. What it actually does for me right now is limiting the set of recognized words to those three, but it simply returns the word I say, without converting it to "next". Looks like it either ignores the <tag> element, or I have to retrieve its content in a different way in my C++/CX program. Or <tag> doesn't work the way I think it does. What shall I change to make it work?
    Have figured it out, at least partially. If I have
    <tag>out.something="something else";</tag> in the SRGS file, I can check whether that was triggered using args->Result->SemanticInterpretation->Properties->HasKey("something");, then retrieve its value with args->Result->SemanticInterpretation->Properties->Lookup("something")->GetAt(0);
