what different between IManipulationHandler and INavigationHandler in HelloToolkit?
Hi Microsoft:
I really like the Holotoolkit you created for me, but have the question as the title said:
what different between IManipulationHandler and INavigationHandler ? seems they are designed to do the same thing, could you tell me In what kind of circumstances should I use IManipulationHandler not INavigationHandler, or the opposite
is there any example I can check?
thanks
this question makes me recall that famous words HRC said: What difference – at this point, does it make?
is anyone knows the difference?
anyway, I am using IManipulationHandler
Do the documents here help around navigation and manipulation? https://developer.microsoft.com/en-us/windows/mixed-reality/gestures
