HoloLens Sharing together with Image Recognition from Vuforia
Hello!
I've developed an application on the HoloLens that uses Image Recognition Features from Vuforia. However now my Task includes implementing sharing to this app. I am Aware that Vuforia has its own ARCamera that it uses and Tutorial 250 also presents the Camera to use with it. I don't think its possible to implement both cameras at the same time, so how is it possible to modify one to Support both Features? Does anyone has a solution for implementing Sharing together with Vuforia Image Recognition?
Thank you!
Yes, its possible. You can just make sure your camera has the components from both examples and any references to them are wired accordingly.
