how do i start an animation when i tap in unity?
OptionsMonday admin
@Shukenmg,
As @timg already mentioned the Holograms-211 course covers this with some nice code examples and it is using the Holotoolkit-Unity Scripts to do most the heavy lifting. A more striped down alternative than the 200 classes may be checking out the 100 class, Origami: https://developer.windows.com/en-us/windows/holographic/holograms_101#Chapter_3_-_Gestures
This has a section (chapter 3) to use the tap gesture on an object that is much more stripped down and easier to understand. How tap works and sending messages to an object that has been tapped. From there instead of creating rigid components you can use Unity's animation Play function on your properly setup animator component: http://docs.unity3d.com/ScriptReference/Animator.Play.htmlCheers,
Ryan11
Take a look at the Model Expansion chapter in the Holograms-211 course.
If you want to perform your animation in response to the select/tap gesture, put content similar to that in ExpandModelCommand() in your own event handler.
then how to i do it with holotoolkit-unity
via gesture manager?
@Shukenmg,
Cheers,
Ryan
so Is this right?
oh and if you are wondering shukenmg and dan are the same
