Take photo in unity w/ holographic opacity
Hi - simple enough to capture an image using similar bits from here, but does anyone know how to get the mixed capture w/ holographic opacity? The docs say "You must have also indicated that you wanted to capture holograms when you created your capture object", but I don't see any way to set this in the 'capture object'. Thanks in advance!
Optionsstepan_stulov ✭✭✭
Hey, @BillMcCrary
Have a look at the example usage of the PhotoCapture calss, namely at the PhotoCapture.CreateAsync method. Its first parameter is what you need.
Cheers
5 -
Ah @stepan_stulov thanks so much - I hoped I was just overlooking some detail and that was it!
Hey, @BillMcCrary
Cheers
https://www.billmccrary.com/
