Store Not Available On Hololens
Mag
There is no Micrsoft Store shown anywhere on the Hololens. I need it to install some apps.
The Store is listed on the Apps in Device Portal. But when I try to Start it, the browser displays the following message:
"Failed to start package Microsoft.WindowsStore_8wekyb3d8bbwe!App"
Is there anyway to reinstall the Store app? My only other option is to reset the entire Device, which I would rather avoid.
Hi @Mag (or anyone else) did you ever find a fix for this problem? I just experienced the exact same problem. Thanks.
@Jason Sorry, it was a while ago, but I believe I had to reset the device. I'm not sure how it got into that state.
