Spatial mapping and bad Internet connexion problem
Hello, I have a question about spatial mapping. I make researchs in the forum's threads, I read that spatial mapping work even if your device is not connected to the Internet... but...
I have a problem, because when I don't use wifi or have a bad connexion, if I shut down the Hololens and start them again, there are 2 possibilities:
1) It won't recognize the space.
2) It recognizes the space, but anchors move completely, sometimes an object I put is like 5 meters away, which is huge.
I never have this kind of problem when I use a good connexion.
Thank you in advance for your help.
Anchors should only be recognized in the same space. So if you have a space in your office and set an anchor there and then the next time HoloLens turns on and thinks that it is in a different space that anchor will not show up because it is registered to a different space.
AR Developer
Thank you for the answer. The anchor show in general, but far away from where I put them...
