Problem with Universal Windows Platform when minimal version is set to 10.0.16299
At first, sorry for my poor english!
I have a problem when i try to take advantage to NetStandard2.0 compatibility (for more info, see https://blogs.msdn.microsoft.com/dotnet/2017/10/10/announcing-uwp-support-for-net-standard-2-0/).
My configuration :
Windows 10 version 1709 (16299.15)
Visual Studio 2017 15.4.1
Unity 2017.2.0f3
I create a new blank project in Unity
Player settings
Scripting runtime version : .Net 4.6
Scripting backend : .Net
Build settings
Target device : HoloLens
Build Type : D3D
SDK : 10.0.16299.0
Build and Run on : Local Machine
Unity C# Projects : checked
After building Visual Studio C# projet, i made 2 changes :
- Update Microsoft.NETCore.UniversalWindowsPlatform Nuget package to 6.0.1 version
- Change in csproj properties Targeting minimal version to 10.0.16299
In this case, i have an error on AssemblyConverter.exe call during build :
Copying unprocessed assemblies...
Running AssemblyConverter...
System.InvalidOperationException: La séquence contient plusieurs éléments correspondants.
à System.Linq.Enumerable.Single[TSource](IEnumerable1 source, Func
2 predicate)
à Unity.ModuleContext.GetCorLibMethod(TypeReference type, Func`2 predicate)
à Unity.ModuleContext.GetCorLibMethod(String typeFullName, String methodName)
à Unity.AddMethodUtilityClassStep.WSA_AddInvokeDefaultConstructorMethod(TypeDefinition type)
à Unity.AddMethodUtilityClassStep.ProcessModule()
à Unity.ModuleStep.Execute()
à Unity.Step.Execute(OperationContext operationContext, IStepContext previousStepContext)
à Unity.Operation.Execute()
à Unity.Program.Main(String[] args)
Any idea to solve my problem?
Thanks
Hi @oleb,
First, your English is great.
Second, the HoloLens runs version 10.0.14393, which is the anniversary edition of Windows. There's no use in targeting a higher version. -- Not sure if that makes a difference in your build, but it might if you are setting your minimal build higher than what the OS actually supports.
You need to reference the version of the package that doesn't have dependencies on your version 10.0.14393. That would be 5.4.2.
