Problems to receive messages from server on HoloLens
Hi guys,
I am developing an app which needs to connect to server in order to receive messages. I am using TCP/IP protocol because I need to establish a previous connection. Becuase of the problem with the System.Net.Sockets library I am using Windows.Networking.Socket library.
The code to use the aforementioned protocol is as follows:
using System; using System.IO; using HoloToolkit.Unity; using UnityEngine; #if !UNITY_EDITOR using System.IO; using System.Threading.Tasks; using Windows.Networking; using Windows.Networking.Sockets; #endif /// <summary> /// TcpNetworkClientManager class provides methods to /// send and receive messages asynchronously /// </summary> public class TcpNetworkClientManager : Singleton<TcpNetworkClientManager> { #region PRIVATE_MEMBERS_VARIABLES [SerializeField] [Tooltip("The Ipv4 address of the machine to connect")] private string ip = "127.0.0.1"; [SerializeField] [Tooltip("The connection port on the machine to use")] private int port = 9999; /// <summary> /// The message we receive /// </summary> private string message; /// <summary> /// Tracks if a client is connected /// </summary> private bool clientConnected; /// <summary> /// Flag to receive message /// </summary> private bool receiveFlag; #if !UNITY_EDITOR /// <summary> /// Supports network communication /// </summary> StreamSocket socket; /// <summary> /// Stream of data to write /// </summary> private StreamWriter writer = null; /// <summary> /// Stream of data to read /// </summary> private StreamReader reader = null; #endif #endregion // PRIVATE_MEMBERS_VARIABLES #region PUBLIC_MEMBERS_VARIABLES public string Ip { get { return ip; } set { ip = value; } } public int Port { get { return port; } set { port = value; } } public string Message { get { return message; } set { message = value; } } public bool ClientConnected { get { return clientConnected; } } #endregion // PUBLIC_METHODS #region MONOBEHAVIOUR_METHODS protected override void Awake() { base.Awake(); Message = string.Empty; clientConnected = false; } #endregion // MONOBEHAVIOUR_METHODS #region PUBLIC_METHODS /// <summary> /// Connects to a tcp server using TCP/IP protocol /// </summary> public void Connect() { receiveFlag = true; #if !UNITY_EDITOR Task.Run(async () => { try { socket = new StreamSocket(); await socket.ConnectAsync(new HostName(Ip), Port.ToString()); clientConnected = true; writer = new StreamWriter(socket.OutputStream.AsStreamForWrite()); reader = new StreamReader(socket.InputStream.AsStreamForRead()); await Receive(); } catch(Exception) { Debug.Log("Unable to connecto to server"); } }); #endif Debug.LogWarningFormat("Tcp connect not supported in editor"); } /// <summary> /// Sends asynchronously a message using TCP/IP protocol /// </summary> /// <param name="data"></param> public void Send(string messageToSend) { #if !UNITY_EDITOR if (writer != null) Task.Run(async () => { try { await writer.WriteAsync(messageToSend); await writer.FlushAsync(); Debug.Log("Sent: " + messageToSend); } catch(Exception) { Debug.Log("Unable to send message to server"); } }); #endif Debug.LogWarningFormat("Tcp send not supported in editor"); } /// <summary> /// Frees resources both reader and writer /// </summary> public void Close() { #if !UNITY_EDITOR receiveFlag = false; if (writer != null) writer.Dispose(); writer = null; if (reader != null) reader.Dispose(); reader = null; #endif Debug.LogWarningFormat("Tcp close not supported in editor"); } #endregion // PUBLIC_METHODS #region PRIVATE_METHODS /// <summary> /// Receives asynchronously a message using TCP/IP protocol /// </summary> #if !UNITY_EDITOR private async Task Receive() { if (reader != null) { while (receiveFlag) { try { if (clientConnected) { string messageToReceive = await reader.ReadToEndAsync(); if (messageToReceive != null) { Message = messageToReceive; Debug.Log("Received: " + message); } } } catch (Exception) { Debug.Log("Unable to receive from server"); } } } } #endif #endregion // PRIVATE_METHODS }
Although I can connect to the server, I do not receive anything. I know that the Receive() function reaches to
but the next statements are not called, that is, the thread is waiting for data, but the data never is received.
Does anyone know what trouble I am having?
Thanks in advance,
Cristian.
I found the solution after trying different approaches. The code that solved the problem is as follows:
char[] buffer = new char[bufferSize]; int bytes = await reader.ReadAsync(buffer, 0, buffer.Length); if (bytes > 0) { string result = new string(buffer, 0, bytes); message = result; Debug.Log("Received: " + message); }
The problem was ReadToEndAsync, since with a stream socket there should be no "end of stream" delimiter.
I hope this approach can help someone,
Cristian.0
Cristian.
