Problem with WiFi credentials
I ran into problems when setting up the hololens. To connect to a WiFi I had to input my ActiveDirectory Credentials. Unfortunately the input field kept being cleared while I was typing. I ended up with shortening my password to be fast enough. But this bug should be solved I think.
I didn't realize this bug still existed. It is infuriating.
From a year and a half ago:
https://forums.hololens.com/discussion/2359/issues-with-wifi-password-entry
Thanks for the reply @mark_grossnickle!
I switched back to the previous OS version because of other problems. The problem does not exist in this built. It seems to have come back somehow.
