Acquisition method of CameraResolution in the research mode
Hello.
I occurred a problem.
And It hasn't resolve yet
I wrote the following code.
cameraResolution = PhotoCapture.SupportedResolutions .OrderByDescending((res) => res.width * res.height).First();
and in the research mode
InvalidOperationException: Sequence contains no elements at System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
Will occur.
I can obtain cameraResolution correctly by releasing the research mode.
I think other acquisition method in the research mode.
Does anyone know the solution?
Hi @ShingoMORIO36 ,
If you don't mind, could you answer a few question, so I could understand your scenario better please ?
1. Is this App a Unity App or UWP ?
2. Have you enabled Research Mode ?
3. Is your end goal to access the PhotoVideo camera or Research Mode cameras ?
Thanks
sshiv
Thank you for your comment.
I tried Unity App.
Yes. I have.
I enabled Research mode.
I want to use both. if I possible.
Can't I use RGB camera on research mode? by any chance.
