WDDM 2.2 level driver for NVIDIA Quadro 4000M ?
Rob2
Trying to setup Mixed Reality Portal on an old Dell M6600 Laptop and everything passes (ticks or !) except the graphics driver which is marked as X.
Any pointers to a compatable driver that is also WDDM 2.2 for a NVIDIA Quadro 4000M chipset would be much appreciated I was thinking that some compatable cards or laptops may have used it and gone further than the driver from NVIDIA although the more I think about it it seems unlikely...
Anyway thanks for reading.. Rob
Hi Rob2,
My name is William and I am with the Windows Mixed Reality team. I took a look on the Dell website and was unable to find any newer updates for the Quadro (see http://www.dell.com/support/home/us/en/04/product-support/product/precision-m6600/drivers), however there is an update from this month directly from Nvidia if you want to try that and see if it updates it to WDDM 2.2, but I cannot guarantee that it will do so. Link: http://www.nvidia.com/download/driverResults.aspx/133957/en-us
I hope that helps!
