How to import CSV to Vcard file Format ?
in General
hello guys....
i would to import some excel data like CSV to Vcard file format, does it is possible to import CSV to vcard format?
If you are looking for CSV to Vcard Software then download this software, this software will help you to convert your CSV to vcard file format. visit at www.downloadtopten.com
Simple, easy and best solution is available here csv to vcard converter tool download this free tool for converting file from csv to vcard file format. Download link here - http://www.osttopstapp.com/csv-to-vcard.html
Try Free CSV to Vcard Converter software from CSV Which is a third party utility, and allows its user to entire selected CSV including name, title, email, phone number etc file and convert them into Vcard file format. This too supports with all the latest versions of Windows 10/8/XP/Vista. Now you can Download free link from here - https://www.softaken.com/csv-to-vcard-converter
There are various third party tools available on the internet, you just need to get the right one. I've used CSV to vCard for Mac Tool when i need to resolve the same issue and got accurate results.
