"Development build" appears on the bottom right hand corner on HoloLens
Hi guys,
I have noticed that when I run my app on HoloLens a text appears on the bottom right hand corner of the screen showing "Development build". The version of Holotoolkit is 2017.4.1.0 and the version of Unity is 2017.4.9f1. Is it normal?
Thanks in advance,
Cristian.
I think you have the development build selected in your Unity build settings turn this off.
Dwight Goins
http://dgoins.wordpress.com
The development build option is not selected. Do you know another alternative that can be causing this problem?
Thanks in advance.
