How to write data into a file?
Hello,
in my Hololens app i want to write data into a file which i can then view over the Device Portal. The Data contains just the time from one airtap on a special object to another airtap.
The problem ist that there will be no file created in the Device Portal under /LocalAppData/YourApp/LocalState
Thanks in advance
Jonathan
using UnityEngine;
using UnityEngine.XR.WSA.Input;
using System.Diagnostics;
using System;
using System.IO;
public class GazeGestureManager : MonoBehaviour
public static GazeGestureManager Instance { get; private set; }
public GameObject FocusedObject { get; private set; } // Represents the hologram that is currently being gazed at. public Stopwatch time = new Stopwatch(); public string path; GestureRecognizer recognizer; // Use this for initialization void Awake() { Instance = this; // Set up a GestureRecognizer to detect Select gestures. recognizer = new GestureRecognizer(); recognizer.Tapped += (args) => { // Send an OnSelect message to the focused object and its ancestors. if (FocusedObject.name == "Start") { time.Start(); FocusedObject.SendMessageUpwards("OnSelectStart", SendMessageOptions.DontRequireReceiver); } else { time.Start(); FocusedObject.SendMessageUpwards("OnSelectCube", SendMessageOptions.DontRequireReceiver); } }; recognizer.StartCapturingGestures(); } public void StartTime() { time.Start(); } public void StopTime() { TimeSpan ts = time.Elapsed; time.Stop(); path = Path.Combine(Application.persistentDataPath, "Messdaten.txt"); using (TextWriter writer = File.CreateText(path)) { writer.Write(ts); } }
Have you tried using the Windows Storage API?
https://docs.microsoft.com/en-us/windows/uwp/files/quickstart-reading-and-writing-files
Use Windows.Storage.ApplicationData.Current.LocalFolder to get the LocalState folder
