EDB Recovery Tool
edited December 2018 in General
To Recover Exchange Mailbox data so use Enstella EDB Recovery Tool. EDB Recovery Tool fastly repair Corrupted EDB files and recover EDB files. EDB to PST Recovery use granular algorithm during recovery procedure is running. It deeply recover folders from Exchange database like (spam folders, contacts, inbox, unread folders, drafts folders, deleted folders and users created folders) etc. Exchange users easily view recover .edb files into PST, EML, MSG and HTML Formats. EDB Recovery Tool also handle large size of PST files by breaking into smaller PST files from (1GB, 2GB, 3GB, 4GB and 5GB). User search limited data from big EDB folders you can take help “Message filtering option”. Enstella EDB Recovery Tools perfectly works with all windows like (win 10, win 8, 8.1 and lower versions).
Note: Enstella EDB Recovery Tools is available at lowest price $99.
Read more: edbtopst.enstella.com/
  • To recover corrupted EDB file and convert EDB to PST, EML, and MSG files, you can use EDB to PST converter tool. This tool works smoothly with corrupted and non-corrupted EDB files and allows users to export EDB files into Office 365 and Live Exchange server. Read More: http://edbtopst2013.blogspot.com/
  • Looking at the requirements of the user, the software nowadays comes as a package with all the features embedded in it. EDB to PST converter is one among the several software to follow this rule. The EDB to PST converter, scans the complete database and recover the deleted files and folders. It has a deep scan feature which recovers the EDB file and restores every component like messages, attachments, mails, tasks, notes, journals, calendar entries and many other such details.
    You can easily convert the EDB to PST file with this software and recover deleted EDB files
  • With the help of an Exchange server recovery software, it is very easy to fix EDB errors and recover lost data. The software also helps to convert EDB file to PST file within few clicks. For more, visit: https://www.nucleustechnologies.com/edb-to-pst.html
  • Fastly re-access damaged EDB data with Enstella EDB Recovery Tool. With this tool users also repair private and public EDB folders. EDB Recovery give permission to users chooses the formats (PST, EML, MSG and HTML) to save the recover data without creating any problems. Users easily operate EDB Recovery Tool in all windows and MS Exchange versions.
    Get a marvelous Exchange EDB Recovery Tool at lowest price $99.
    Read more: enstella.com/exchange-recovery.html
  • Easy solution for exchange EDB recovery tool just come at Stella Data Recovery and download smart program for repair damage exchange EDB file data and https://www.stelladatarecovery.com/blog/how-to-convert-edb-to-pst-in-office-365/convert EDB to PST file with such its items like as:- EML, MSG, HTML, MHTML, MBOX, DOC etc. This SDR Microsoft EDB to PST conversion manager is professional tool for extract file from direct live exchange server and save to PST format.
    Download this application:- https://www.stelladatarecovery.com/edb-exchange-server-issues-and-solutions.html
  • Exchange Administrator and the naive user can Exchange Recovery Tool. The Exchange Recovery is a standalone utility for Recovering Damaged Exchange Server EDB Files.
    1) Support Public, Private & STM File of Exchange Server
    2) Support Exchange 2019 & Below Environment
    3) Export Recovered Data into Live Exchange Environment
    4) Export Recovered Data into Live Exchange Online Environment
    5) Save Recovered Data in PST, MSG, MBOX, PDF, HTML File format. To know more visit: https://systoolsgroup.com/exchange-recovery.html
  • SysInspire EDB to PST converter Software is considered as the most efficient EDB recovery tool. It can repair Exchange EDB data smoothly and save it in many different file formats like PST, EML, EMLX, MSG and many others. It extracts email along with all meta properties such as bcc, cc, to, from, contacts, attachments, and others. Also, this tool is available for free in the form of a demo.
    Explore more about free EDB to PST converter software here
  • Try also the tool and easily recover and convert edb files in PST format. Read more https://exchangedatabaserepair.weebly.com
  • The EDB to PST tool from EdbMails can effortlessly recover your information even in cases where the corruption is too extreme to handle for native utilities.
    **A few important features of the software are :
    Maintains the folder structure and doesn’t alter the contents of original EDB file.
    Repairs most common EDB errors and corruption issues.
    32 bit as well as 64 bit Microsoft Office deployments are supported.
    Public and private folder recovery supported.
    Capable of recovering and restoring accidentally erased the user mailboxes from the exchange database.
    Restore all mailbox information including emails, contacts, assignments, timetable and so on from them.
    No exchange server logs required for running.
    EdbMails Supports exchange server versions 2016 / 2013 / 2010 / 2007 / 2003.
    For more information and downloads please visit : https://www.edbmails.com
  • Recover lost and deleted data from both private (priv1.edb) and public (pub1.edb) folder of your Exchange EDb file with the help of the best eSoftTools EDB to PST Converter Software. by this software user can Recover and Converts selective single and multiple EDB file folder to Outlook PST with maintaining all emails structure. It supports all MS Exchange and MS Outlook version (include 2019, 2016, 2013, 2010, 2007, 2003, and below version)
    Get More Info: https://www.esofttools.com/exchange-edb-to-pst-converter.html
  • If you looking for Exchange Server Database recovery software, So for that, you can refer to Exchange EDB Recovery tool. Then you can easily recover your corrupted edb files. EDB tool is a dignified tool which helps in repairing of corrupted EDB files. EDB Recovery Tool follows an algorithm which makes it easy for large organizations as well as an individual user for its usage. The software is user-friendly as well allows saving selected items individually in multiple file formats such as .msg, .eml or .html.
    For more information refer to- https://www.bitdataconversion.com/exchange-edb-recovery.html
  • There are many EDB Converter in the market but most reliable and trusted one is InQuit EDB to OST Converter. This tool can put full stop to all the problems that you face while converting the data. If your EDB file is heavy in size so you can split it into several smaller bit of PST file formats without losing any data. You don’t need to install MS Outlook in your system for the conversion process of EDB to PST. It supports PST, MSG, EML, vCal, EMLX, vCard, MBOX and HTML saving formats. This tool can convert recovered PST data into smaller bits from 1GB to 5 GB. InQuit also provide a free demo facility that allows you convert 30 emails per folder free of cost.
    Read more Info: https://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
  • edited August 27
    If you want to recover all the lost Exchange EDB file database to the PST file without making any changes in the internal items of EDB like (emails, contacts, task, journals, drafts, appointments, and calendars). So first of all you have to Download this eSoftTools EDB to PST Recovery which is the best solution to convert the Exchange EDB file into many file formats (like PST, EML, EMLX, MSG, and HTML). All Exchange users can easily get a free demo version of this software from the given link which can easily recover and export 25 items from each folder of EDB file to PST.
    Get More Info:- https://esofttools.com/edb-recovery.html
