Which is the best tool for MBOX to PST Conversion
Regain MBOX to PST Converter is a amazing tool to perform effortless migration process from an MBOX email client to MS Outlook. this Regain MBOX to PST Converter Software facilitates to carry out the Conversion of MBOX files created in these 17+ email clients, i.e. Entourage, Thunderbird, Pocomail, Spicebird, AppleMail, Mulberry, Eudora, Netscape, SeaMonkey, OperaMail, ClawsMail, Evolution, Mozilla Mail Users can check out the support for their specific email client by downloading its free MBOX to PST trial version.
Maintain Folder Hierarchy:-
This tool maintain the intigrity of data and the hierarchy of emails folders. Regain MBOX to PST Converter Software remain the same structure of MBOX data after conversion as it was before. You can Convert your all MBOX file into PST file format without losing any data.
Support All MS Outlook Version:-
This tool Supports all the latest version of MS Outlook and Windows Platform. This Software Compatible with MS Outlook 2003, 2007, 2010, 2013, 2016 and 2019. Just use the Free version to see Original Results.
Try this tool free trial version from here:
http://www.regainsoftware.com/mbox-to-pst-converter.html
  • This MBOX to PST Converter software has the ability to convert large number of MBOX files via batch conversion mode. Mail converter tool easily perform corrupt data recovery and preview of file before begin conversion process. User can view converted emails in CSV format. It provides you with a stop solution for successful conversion of MBOX to PST files.converts popularly used MBOX/MBX email clients to Outlook PST file
    Visit at ; https://www.mailvare.com/free-mbox-to-pst-converter/
  • If you are looking for any tool which might help you to get convert MBOX to PST, then I will recommend you to use Total Mail Converter. This software manages your emails outside your mail client. Attached files can be extracted and placed into new or same path/folder. You can download it from here - https://www.coolutils.com/TotalMailConverter
  • edited March 2019
    I would like to suggest try MBOX to PST converter from Shoviv which is a reliable and secure solution for MBOX to conversion.
    For further info visit here: https://www.shoviv.com/blog/convert-mbox-to-pst-file/
  • Hi if you are looking mbox to pst conversion tool so I want to suggest best mbox to pst converter software this software can convert mbox file into multiple file formats like mbox to PST EML EMLX MSG PDF etc. it can convert password protective and corrupted files and also import all meta propertied and folders, it support all ms Outlook versions
  • I want to suggest a trusted solution, which takes a few simple steps to import the MBOX to PST format. The name of the tool is MailsDaddy MBOX to PST converter that is built on a single wizard. It is able to preserve folder structure, rich text formatting, inline images and attachments. The tool supports all window versions and provides adaptable PST file for Outlook 2019, 2016, 2013 and other older versions.
  • I suggest the best tool to convert the MBOX files into PST format and also into multiple file formats such as EML, EMLX, HTML, PDF. This tool is supported by various email clients such as Thunderbird, Entourage, Apple Mail, SeaMonkey.
    Click Here : http://www.mboxmails.com/
  • There are many tools online that you can download easily. You can check the features first.
