OST4 - Microsoft OST to PST Converter
Microsoft OST to PST Converter application that helps to recover data and convert them into a new accessible file format that is PST file. The software is known for its great work that helps to recover emails, notes, contact, sent item, delete item, attachment, task, draft, inbox and journals from OST file and convert them into accessible PST file format. This single tool is equipped with many amazing features that are the best thing of this utility.
Amazing work of OST to PST Converte.
• Easily recover data of OST file and convert them into Outlook PST file.
• Will be able to export single as well as multiple file formats without any difficulty.
• Display the preview of the recovered mailbox before finishing the conversion task.
• It supports MS Outlook versions like 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
• The users can extract password protected and encrypted data file in a secure way.
• Users can export their data into multiple amazing file formats like PST, EML, EMLX, MSG, vCal, vCard and MBOX.
• The users can export the data of OST file directly into cloud-based application Office365 & Live Exchange Server.
• It supports 24x7 technical support.
• The utility provides a demo version to convert 30 emails from each and every folder free of cost.
Read more: http://ost4.com
  • Microsoft OST to PST Converter tool is encompass Batch Converter module for bulk or single record restore and get better with convert to PST at a time. OST to PST Converter Software allows customers to restoration of selective items from offline OST record and restore OST file into more than one formats along with PST, EML, EMLX, MBOX, vCal, vCard, and HTML. Cloud-based application Office 365 & Live Exchange Server are the extra functions of this device, which assist to keep the file at the cloud-based totally. Software gives you a couple of option for saving OST record into man or woman PST file like as:- EML/MSG/HTML/EMLX/MBOX/TXT and outlook profile.
    Know More - https://inspire-ost-to-pst-converter-software.en.softonic.com/
  • Microsoft OST to PST Converter tool from Shoviv is providing a quick solution to convert OST to PST file. Using this tool, users can do batch migration from OST to PST, Office 365 and Live Exchange server. It also allows users to save OST data into HTML, RTF, Cal, vCal, and vCard format.
  • With the help of OST to PST Converter, you can easily export single as well as multiple files in a few little moments without any complications. Before the actual conversion users can see recovered mailbox preview that is the best facility of this program. The users can export single as well as multiple files at one time without any hassle. It gives you an accurate result that is better than your requirement. According to your wish, you can also export your data into many file formats like PST, EML, EMLX, MSG, vCal, vCard, MBOX and HTML file formats. Apart from its support cloud-based application Office365 & Live Exchange Server.
  • InQuit OST recovery tool a quick solution of corrupted outlook OST file that can recuperate, any size of OST file and efficacious work to repair corrupted OST file. It allows recovering lost or deleted mailbox items from OST files such as emails, attachments, drafts, calendars, notes, journals, contacts and then restoring them into new PST file.
    Read more: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
  • If you are encountering difficulties with transforming OST files to PST format, you can use the OST to PST application which is easy to use. It supports all MS Outlook versions. This utility also converts OST files to PST, EML, MSG and many more. Get more details here: http://www.osttopst.mergepstpro.com/
