OST2PSt Converter
I have a 4 GB corrupted OST file and I want to open it. But it is not showing any response in Outlook. So I'm thinking about the manual process to convert in PST file. If anyone is aware of the manual method then tell me or freeware is available, then please give me suggestions.
  • Outlook generally provides a solution to repair corrupted and damage OST or PST file. But we need a solution at that time, when we want to convert OST to PST format.
    There are several reasons for OST to PST conversion.
    Like:
    1. You have not connected with exchange server.
    2. Configure an online account via IMAP in Outlook 2013 or above version.
    3. Synchronization failed.
    4. Highly corrupted OST file.
    ...And many other scenarios applicable.
    At that time we need a reliable solution that exports the complete data from OST to PST converter.
    To meet all of your requirements, I want to suggest SysBud OST to PST Converter. This single wizard application is the cheapest solution and able to convert highly corrupted, damage, orphaned and inaccessible OST file in PST format. You can install and run this tool on any Window OS and easily perform the conversion.
  • Hi mohitkeshari,
    Manual Process is very long process. Because I was same problem with me before some day then my friend suggest me Inspire OST to PST Converter. I have use first it demo version and I recover my 30 email without pay any money, after then I was purchase technical licence and recover our 50 GB file in few click.
    Thanks
  • A corrupted or orphaned OST file is not supported by MS Outlook email client so after the corruption, the file becomes useless for you until the data is migrated in other formats. Apart from OST format Outlook uses PST format so you need to export OST data in PST format. For this, QuickMigrations Software provides a best and simple OST to PST Converter tool that repairs the OST file and converts OST to PST in a single click.
    Get more details from here: OST to PST Converter
  • Now you can simply switch OST to Outlook file format for Outlook and other OST file supported email clients. The OST to PST Software will change OST file and export into OST format including complete essentials such as emails with attachments, to, cc and bcc, body content with rich text format and more.
    You can download it free of cost; free trial version will consent users to convert 10 emails from OST file into Outlook PST format. This application does not only change OST file to PST format but it also capable to spread OST file into PST file format.
    Source: https://www.sametools.com/convert/ost/
