Easy to use tool to Convert EDB to PST
Exchange server admins often wonder how to recover exchange database file. This used to worry them in the past mainly because the methods available for exchange server database recovery where varied and complex. Nowadays however a lot of tools are available that can help deal with exchange server corruption issues. It is important to choose the right to so that you don't have to regret later.
The simple and most effective way to perform Exchange recovery is to convert EDB to PST. This helps to efficiently retrieve all the information from your Exchange EDB file and convert it to Outlook PST. The PST files can be used for archiving Exchange mailbox information. They can also be opened in various versions of Outlook and the content within viewed.
Let's are the things that should be kept in mind while selecting an Exchange Recovery tool:
First and foremost all the information such as tasks, journals,zip attachments,Inbox items,calendars etc from corrupt or inaccessible databases must be recoverable.
It should allow export to single PST or multiple PST files
Selective export : Must allow migrating exactly what one chooses.
Should support all versions of Exchange Server
Must support Public and Private folder migration to PST
Must be capable of recovering accidentally deleted mailboxes
One professional EDB to PST Converter utility that fits all these criterias perfectly is the Exchange EDB to PST software from EdbMails. It is a one stop solution for all your Exchange server recovery needs.
It has the capability to recover information from even the most corrupt of Exchange Server databases using its advanced deep scanning algorithms. It also supports archive folder migration.
The intuitive user interface that EdbMails sports makes it easy for even non technical users to make use of it get EDB to PST Conversion done. There is even a free trial version of the EdbMails EDB to PST Converter tool that helps convert upto 30 items per mailbox/ folder and test out all the features that EdbMails has to offer.
