Best Way to Convert OST to PST
Regain OST to PST Converter is able to Convert OST file into different platforms- EML, MSG, MBOX, HTML, ICS, VCARD and Outlook PST. The Software has a smart solution and provides the best conversion of corrupted and unworkable OST files. this Software Export all Email items like emails, attachments, contacts, notes, calender and journals etc. You can save 30 emails per folder at free of cost by using this Software free demo version.
CheckOut this Software free demo version from here: http://www.osttopstconverter.emltopstutility.com/
  • AngeliqueAngelique
    edited June 2019
    Hi User,
    According to my opinion, You have to try first Demo version of this OST to PST Converter software, My Company using this tool. This tool develop with latest features.
    Thanks
  • Have a look here: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
    This is an article about OST to PST conversion. May be it helps you more.
  • Using OST to PST specific function of Exchange OST to Outlook PST conversion utility a user can divide or split OST file which results in PST file in a required size. The software supports all version of MS Outlook including 2000, 2003, 2007, 2010, 2013 2016 and 2019 with ease. Before the conversion task you can see preview of recovered mailbox. The software has multiple file formats to collect the final data after the conversion. The file formats are PST, EML, EMLX, MSG, vCal, vCard, MBOX and HTML. Apart from it support cloud-based application Office365 & Live Exchange Server.
  • edited July 2019
    With the help of SysOZ OST to PST Converter Software, you can smoothly and wonderfully Extract OST file with every email metadata- to, cc, and bcc, from, date, time, and subject in few minutes. Superb OST recovery Software helps you to transfer data from OST to PST in few movements. Free demo version is also available that convert 30 emails in each folder.
  • OST to PST Conversion Software that is smoothly recover exchange mailbox data and convert OST file data into working MS outlook PST file other format like as:- EML, MSG, MBOX, and EMLX as well as it also supports all version of Outlook like, 2000, 2003, 2007, 2010, 2013 and 2016.
    For more detail:- https://www.completeconverter.com/ost/
  • To perform hassle-free migration from an OST email client to Outlook through OST to PST Converter Download. It speedily performs OST to PST Tool without making any data loss. The software supports all versions of Outlook.
    Get more info here: https://www.sametools.com/convert/ost/
