Matlab/Unity/C# integration
I was wondering if anyone has experience integrating Matlab into Unity/C#. I have a bunch of image/video processing software I have already developed, and was wondering if it would be possible to utilize those for HoloLens development. For example call a Matlab function.
Any ideas?
This discussion has been closed.
I guess the fact that it is high level is what is attractive in terms of testing out ideas, (and the fact that I already have a library of stuff I have written). This is only to help testing/development go smoother.
I am with you, I suppose if you don't mind poor performance, you may be able to find a Matlab c# interpreter of sorts out there. I did a quick search and I found a few people discussing Matlab in .NET. Some look to be even interfacing with Matlab that's installed and having it run and passing the results to .NET. It's something to check out, but will require a bit of effort.
Thanks, I checked those out, will update if I get something working.
I did some poking around, and I couldn't find anything made available publicly. The most plausible suggestion I saw suggested using UDP to transfer data between the Unity application and MatLab.
Well, I didn't post any links before because this forum flags my posts for review, but the "dot" thing seems to do the trick. Matlab has .NET libraries you can integrate:
mathworks dot com/help/matlab/using-net-libraries-in-matlab.html
You can then make a .NET plugin for Unity. I am not sure, but I'd assume you'd still have to migrate over your code to c#, but you'd at least have the help of Matlab specific functions.
Thanks for the tips, will update more if I can get a smooth Matlab integration up and running.
If I understand correctly you're essentially wanting to call Matlab from C#. I have not had luck using the Matlab COM approach. Instead I preferred using the automation flag.
Change the following path to your enviro and run this from a command line:
"C:\Program Files\MATLAB\R2016a\bin\win64\MATLAB.exe -automation"
This will simply start up a Matlab automation server window.
The -r switch will automatically run your Matlab function:
"C:\Program Files\MATLAB\R2016a\bin\win64\MATLAB.exe -automation" -r MyFuncName(param1 param2)
If you use Powershell instead of cmd.exe you can pipe the Matlab results back to your calling C# app.
Don't see why you couldn't write a C# app running on Hololens that spawned a remote Powershell instance,(cloud VM or another machine) and retrieved the results. The Hololens would just be the caller/retriever
N6MAA10816
