Manual Strategy for Lotus Notes to Office 365 Migration
Manual way to migrate Lotus Notes to Office 365:
To migrate Lotus Notes to Office 365 or Exchange we have to take the assistance of IMAP Connector. Below referenced are the means for Lotus Notes to Office 365 movement:
Backup NSF records:
Most importantly, back up your NSF records by manual procedures. In the event that your relocation fails and NSF documents get degenerate amid the relocation, you can recuperate the mailbox information from the backups.
Create new Mailboxes for every NSF client
Presently, make new mailboxes for every client who has an account in IBM Lotus Notes.
Enable IMAP TCP/IP port:
You have to empower the IMAP TCP/IP port for every client account. Simply pursue the up and coming strides to do likewise:
Open Domino Administrator in Lotus Notes Application
Go to the Configuration tab
Open the Server archive which executes the IMAP administration
Snap Ports, then Internet Ports, then Mail tab
In Mail (IMAP) segment, change the ‘TCP/IP port esteem status’ to Enabled
Snap the Save catch to spare the progressions and close the application
Synchronize with IMAP Connector:
At last, use IMAP connector to synchronize mailboxes between Lotus Notes and Office 365.
Also, view advanced featured Bitacube Lotus Notes to Office 365 Migration Tool: bitacube.com/lotus-notes-to-office-365-migration.html
Manual Process for Lotus Notes to Office 365 Migration is a quite lengthy, tiresome and risky task for the user. The manual process has so many limitations to export NSF contacts, calendars, emails, notes, journals, tasks, etc. in the Office 365 platform.
The manual process exports maximum 1GB data of email folder of NSF mailbox. It doesn't export contacts in Office 365.
For this, here I recommend you, use the most trustworthy solution to Migrate NSF data to O365 migration. Try MailsDaddy Lotus Notes to Office 365 Migration tool.
Manual Trick:-
1:- Firstly transfer data form Lotus Notes to Outlook
2:- After that export Outlook PST file into Office 365.
But this process is lengthy and time-consuming & a lot of chances of data loss.
So personally I recommend you, use SysBud NSF to PST Converter which helps to trasfer NSF file into Office 365 without any hassle. As well as you can transfer your Lous Notes file into PST, MBOX, MSG, EML, HTML, RTG, and many other popular formats.
For more details:- http://www.softguide.com/program/sysbud-nsf-to-pst-converter
Import email from Lotus Notes file to Office 365 first, you have to transfer Lotus Notes data to Office 365. So, the best way to perform OST to office 365 migration is with WholeClear NSF to Office 365 Converter. Using this software you can directly export emails and other items from NSF file to office 365 server.
If you want to migrate Lotus Notes data or mailboxes to office 365 and other formats, according to my experience use third party tool, Shoviv Lotus Notes to Office 365 because it easily migrates bulk NSF data into Office 365, Live Exchange, Outlook PST and also exports data into EML and MSG formats with taking a time without any data loss. It provides better security, For the demo, download its free trial version to test the tool and also migrate the first 25 data items per folder.
More details, visit:- https://gust.com/accelerators/migrate-lotus-note-mailboxes-into-office-365
