How we can easily merge various PST file ?
in General
I am facing this problem last three days, I have no idea how can I easily merge PST file. If you have any idea please share here.
Hello
If you want to merge the multiple PST files into single PST files then I would suggest trying to use the KDETools Outlook PST Merge. This tool easily merge the multiple PST file into single PST files. This tool checked by IT-Experts.
Features:
Visit Here: http://www.merge-pst.com/
Merge Outlook PST File Tool is easy to combine software that helps users to access the email statistics of merge PST software supported email clients. It is a secure, quick and reliable technique with the aid of which users can effortlessly merge PST Files with all attachments.
In order to merge multiple PST files 100% successfully, I would recommend you to use Stellar Tolkit for Outlook.The software facilitates the option to merge or join PST files easily without loss of a single email. By using this merge moduleof the software, you can merge or join all Outlook items like Emails, Calendars, Contacts, Notes, Journals and Tasks. Read more details here: https://www.stellarinfo.com/email-tools/outlook-toolkit.php
Follow these steps to merge multiple PST files in Outlook 2016, 2013, 2010, and 2007.
1. Start and run Microsoft Outlook and then go to File >> Open >> Import option.
2. The Import/Export wizard opens up next. ...
3. Select the option Outlook Data File to import that file type.
4. Click on the Next button.
Regards.
Aby
Apps4Rent
