Hololens Emulator Credentials?
Everything seems to be setup correctly as I do not have any errors. But the emulator keeps on a black screen saying: "OS is starting". A separate windows pop up asking for credentials to connect to "RD Gateway Server". After trying all credentials and fail, once you hit close, the emulator also closes and another windows pop up: "XDE:023 The connection to the virtual machine is lost. The virtual machine might be disabled by another application. The emulator must close".
If I let the credentials window open, I can go to links on the right, but the emulator always show only the black screen with "OS is starting". and after many minutes, if the credentials window is not closed, a new window pop up saying: "XDE:014 The emulator is unable to connect to the device operating system. A connection attempt failed because the connected party did not properly respond after a period of time, or stablished connection failed because connected host has failed to respond Microsoft.Xde.Base.Connection.HyperVSocketEndPoint"
The hyper V is turned on. Any ideas what I am missing? Thanks.
Hi, @francisco , were you able to resolve this issue?
