Import MDaemon to Exchange
Here I would like to talk about, how you can import data from MDaemon to Exchange. Importing from MDaemon to Microsoft Exchange Server is like next to impossible. I would like to suggest MDaemon to Exchange Converter tool that helps their users to migrate data from MDaemon to Exchange Server 2019, 2016 and all other versions. The tool allows you to perform complete MDaemon data migration to Exchange Server. The Tool is capable to convert multiple and large MDaemon files to Exchange Server, there is no limitation for file size.
How to Import MDaemon to Exchange Server?
1 – Download >> Install >> Launch MDaemon to Exchange Server Tool
2 – Software will automatically browse MDaemon data from its default store location or you can also add manually MDaemon data files
3 – Select to convert Exchange Server option
4 – You will be asked for your Exchange Server account details >> fill up your Exchange Server user account details
5 – Click on Convert >> and software directly import MDaemon data into your Exchange Server account.
**Features of MDaemon to Exchange Converter tool
1 – Export MDaemon WorldClient data to Exchange Server
2 – Import MDaemon to Exchange Server 2019, 2016, 2013, 2010 and all below versions
3 - Tool offers the simplest and easiest Graphical Interface
4 – Export MDaemon data (emails, contacts, mailboxes, calendar data, task, attachments, notes, and other folders) to Exchange Server.
5 - Maintains MDaemon Folder Structure, attached files, and folders, data formatting, Key Elements of Email.
    For MDaemon to Exchange migration, you can also give a try to MDaemon Converter. All-in-one solution that directly export MDaemon emails, contacts, calendar and other items to Exchange without any data loss trouble. It is fast, reliable, secure and guarantees data accuracy. You can check the process of MDaemon Converter on your own by downloading the freeware edition of the tool that allows to migrate first 25 files per MDaemon folder to Exchange free of cost. Besides Exchange, you are free to migrate MDaemon to Office 365, Outlook.com, Outlook, Hosted Exchange, Gmail, G Suite, Yahoo and more.
    Follow these steps for Exchange migration:
    Step 1 : Browse and add MDaemon email files.
    Step 2 : Select mailbox folders and click Next.
    Step 3 : Select Exchange Server as Saving Option and Enter its login credentials.
    Step 4 : Click Convert button and analyse the migration process.
    I hope this helps!
    Aby | CloudDesktopOnline
