Manipulation gesture causes crash
I am trying to integrate manipulation gesture recognizer into my painting app. As suggested by the forum moderator (thanks a lot!), the drawing looks perfect and smooth. However, right now we are suffering with the 'Access Violation' issue that causes the app crashes. I know there is another forum thread that talks about this but I just want to fully understand this.
What does 'Access Violation' exactly is? Does it happen when I try to access the x,y,z coordinates of the current manipulation position or somewhere else?
I know that the skype is using the manipulation gesture recognizer. How did you guys solve this? Is there a way to catch it or something?
Andy
Optionsahillier mod
Hello @boruil,
Be sure to update to the latest version of Unity (b16) that was released on 5/5. unity3d.com/pages/windows/hololens
If you check the release notes for b16, you'll notice that Unity just fixed a crashing bug related to Manipulation.
If you still see this crash after updating to b16, please let us know!
~Angela5
Hello @boruil,
~Angela
@ahillier Thank you sooo much for your help! Saved my life!
Following this advice, I just downloaded b17. When I tried to build my app that was created with b10, I received the message "No Windows Store module loaded." The "Open Download Page" button just launched a blank browser window. How can I get the Windows Store module?
Any help will be appreciated.
When you download the new unity you also need to download the new UWP runtime. That should fix your problem.
Where can I find the new UWP runtime?
Bottom of the page click on UWP Runtime which is the new b16 Metro Editor update at
http://unity3d.com/pages/windows/hololens
Unfortunately the b17 version is for Standalone Windows.
If you go File -> Build, you CANNOT see the Windows Store Build in the Platforms list, Just install the versions from the above link which is b16. Just delete the b17 desktop link.
