Simple move animation
Hi, I am new to Unity and have a question about animation. I just want to move a GameObject from point A to point B and would like the viewer to see the movement, what is the best way to do it?
Thank you very much.
Fireman
Check out Rick Barraza's Creative Coding with Unity - it is the prefect introduction for Unity, and most of what you learn will be immediately applicable to HoloLens development as well.
@vbandi Hi
I am getting the below errors as I am trying to give command to one animation.
I am new to coding and I was hoping you can give any input as to what I am doing wrong. Thank you
You have made several syntax errors. Here is what the Update method should look like:
void Update()
if (Input.GetKeyDown("1"))
anim.Play("idle", 1, 0f);
Pay attention to the placement of the semicolons and the {}.
I recommend never using the shorthand notation for if statements. Others may not be that strict, but my own code styling I always do this:
void Update() { if (Input.GetKeyDown("1")) { anim.Play("idle", 1, 0f); } }
That way you can easily link up opening and closing brackets (every open bracket must have a closing one), and it's easier to see what is referred to by the if statement. Just a suggestion, if you're new to coding, you'll want to explore different coding styles out there and adopt it for all your coding for consistency.
@Fireman for more complex animations and movements (sequences/easing/etc) you may want to check out Dotween. Its fantastic and free: http://dotween.demigiant.com/
