Error Deploying in Debug mode
nash
I'm having an issue where I need to get to some information that isn't available when debugging in Release mode. Specifically what's happening is my "OnGazeEnter" / "OnGazeLeave" events are not firing.
I would like to get more information about the gameobject GazeManager is colliding with but when I inspect the object while debugging in release mode I get the 'cannot view because code is optimized message'
When trying to run the same code in debug mode i get this error, how can i get more info about this error?
The program '{my app}' has exited with code -2147483645 (0x80000003).
Try Debug.Log style logging, putting break points.
When you enter debugging it may ask you to hit continue or 'disable just my code' kind of settings.
